82 Users Online (81 Members):
Forums >> Revit Building >> Technical Support >> Ceiling Tiles
2 Posts No Rating |
Does anyone know how to edit a ceiling system. i currently need a 2' x 2' grid panel system. i am having problems trying to obtain this family. Also, how do you rotate an existing grid or get it to go in the opposite direction
You just need to click the ceiling tool>then in the properties>click edit new duplicate, then modify the system to use a material that has the 2x2 pattern. To create a 2x2 pattern you need to go to the fill patterns dialog box and click Model>new> cross> enter the dims you want. If you want them all rotated 45 you can do that here. Or if its just a few once the ceiling is in place you just tab to select a line of the pattern then click rotate.
How to create a custom compound ceiling? |
Thu, Nov 5, 2009 at 12:53:14 PM
How to make a Detailed Ceiling |
Wed, Mar 25, 2015 at 8:53:41 AM
3D Roof Tiles for temple |
Sat, May 15, 2010 at 6:55:41 AM
Scheduling # of Floor Tiles |
Thu, Oct 6, 2011 at 6:51:01 PM
how T-BAR with no Tiles |
Thu, Nov 27, 2008 at 12:47:50 PM
Members: | 2057827 | Objects: | 23076 | Forum Posts: | 152250 | Job Listings: | 3 |
