176 Users Online (175 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Corner Trim with Vertical Sweeps
Tue, May 29, 2007 at 11:44:02 AM | Corner Trim with Vertical Sweeps
DPArch
I am trying to add corner trim.  I have created a profile family to do a wall sweep and I have it loaded.  When I try to enter the sweep, it will not put the sweep on the corner.  It will only get within about 6" of the corner.  I have tried placing it, and then moving it to the corner but I get an error that says that the "sweep position is outside of its wall"  Any ideas what I am missing here?
Tue, May 29, 2007 at 3:29:54 PM | Corner Trim with Vertical Sweeps
sdbrown
5 Stars: 3 Votes
You should use a generic model or line based family for corner trim. Hosted sweeps don't work well for this application.
Tue, Sep 11, 2007 at 11:06:08 AM | Corner Trim with Vertical Sweeps
keyaggie
I am having the same problem, but not on all the corners.  I did create my profile as a generic wall based, but i cannot get to it as a profile to select in my element profile, I am using the host sweep\wall sweep\trim.  the only profiles i can get are the standard ones and the ones i created as a hosted profile.
So the profile i have been using was created as a host base profile and it is working in most corners, but then it wont work on others...it comes within a few inches of the corner then dissapears???  any ideas?
Tue, Oct 21, 2008 at 10:29:40 AM | Corner Trim with Vertical Sweeps
Michael4Weber
I think I just resolved that issue with the Sweep coming off that wall.  Sometime when the walls turned a corner there was only about 3 in. that actually turned the corner.  You need to use the Edit Wall Joint command and mitre the corners.  That way you have total wall length to the corner.
Thu, Aug 31, 2017 at 2:32:52 PM | Corner Trim with Vertical Sweeps
RadiusDesign
i use the wall join configuration tool. make sure your walls are going the right (see attached) make a outside and inside corner profile, vertical sweeps. much easier.
Vertical trim ***PLEASE HELP****
Tue, Jun 12, 2012 at 8:05:23 PM
Vertical Wall Sweeps
Wed, Nov 7, 2007 at 4:46:09 PM
Thu, Sep 13, 2012 at 7:52:25 AM
12
Wall sweeps - trims
Thu, Jan 3, 2008 at 3:26:59 PM
Trimming sweeps
Wed, Jan 25, 2006 at 3:50:56 PM
Page generation time: 1.0271
