110 Users Online (109 Members):
Forums >> Revit Building >> Technical Support >> Revit Roof Cut Level Error
16 Posts No Rating |
Hi All, I am unable to draw a roof on a just four walls at a particular elevation. I get an error message "Cut Level Can't Be Below Bottom of Roof". I have adjusted the View Range parameters in many configurations and still get the message. If I draw the roof at a lower evlevation no problem !! Help please???
CLICK ON THE ROOF PROPETIES BOTTON AND INSIDE THE DIALOG BOX CHANGE THE CUTOFF LEVEL TO NONE
Hi cirees--- You can only access the roof cutoff button after the roof is finished---- I get the error after sketching the roof lines --- I am prevented from finishing the roof----- perhaps someoe has another approach???--- learning in the early stages is frustrating --- I hope someone can save me from total frustration---- I am usually a good student--Thanks
not the properties button in the Status Bar, look to your left in the design bar. you will see "Roof Properties" HTH
Hi Cirees---I feel really dumb but I don't see Roof Properties in the Design Bar??? ver 9.1
After you click roof>roof by footprint, the design bar to the left changes. This is one thing you CONSTANTLY have to watch for in Revit. The interface changes when you select a command just about every time. Especially the options bar. Good luck and welcome to RevitCity
Thanks for the additional hekp Frameman----- problem solved--- you guys are great---thanks
Roof Problems |
Wed, Mar 5, 2008 at 2:07:33 PM
Serious Error when creating Level |
Tue, Dec 16, 2008 at 5:04:05 PM
Pitch roof problems- double-plumb roofs with different height edges |
Thu, Feb 21, 2008 at 2:54:46 PM
Roof, Roof, Tower and nary a boolean to be found |
Thu, Apr 8, 2010 at 5:02:02 AM
Roof Cutoff Level/Offset |
Fri, Apr 2, 2010 at 5:09:24 AM
Members: | 2057787 | Objects: | 23076 | Forum Posts: | 152250 | Job Listings: | 3 |
