59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> circular openings in concrete walls
Thu, Dec 18, 2003 at 11:47:43 AM | circular openings in concrete walls
tomm
Newbie question. I often need to make circular openings in concrete walls. In creating a family which includes one of these openings I sketch the circle using the circle tool. When I try to finish the sketch I am told that the circle is not closed, and find there is a small opening in it. If I try to sketch a line to close the circle I get an error message that the line is to short. If I try to drag the ends of the circle together I get an error message that the element is too small. Is there a way to sketch a closed circle? Thanks in advance
Tom McLaughlin
Thu, Dec 18, 2003 at 11:49:59 AM | RE: circular openings in concrete walls
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
It seems like you are trying to sketch the circle with the arc tool. Try sketching your circle with the circle tool, which is always a closed circle. hope that helps!
Hiroshi Jacobs
Thu, Dec 18, 2003 at 12:28:34 PM | RE: circular openings in concrete walls
tomm
I have tried with both with the same results. Should I have anything special in units, or snap settings?
Thu, Dec 18, 2003 at 12:35:28 PM | RE: circular openings in concrete walls
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
so when you use the circle tool it has a gap in it as well?
Hiroshi Jacobs
Thu, Dec 18, 2003 at 12:36:34 PM | RE: circular openings in concrete walls
tomm
Quoting hjacobs - 2003-12-18 12:35:28
"so when you use the circle tool it has a gap in it as well?"
Thats correct.
Post edited on 2005-06-13 03:47:15
Thu, Dec 18, 2003 at 12:40:18 PM | RE: circular openings in concrete walls
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
very interesting... perhaps you could email me the file so I can take a look at it... hiroshij@oculusinc.com
Hiroshi Jacobs
Thu, Dec 18, 2003 at 12:45:22 PM | RE: circular openings in concrete walls
tomm
Thats correct.
Post edited on 2005-06-13 03:47:58
Thu, Aug 5, 2004 at 10:12:34 AM | RE: circular openings in concrete walls
hotrod67
Take a circular window family,copy it and rename it to Circular Wall Openings. Remove the glass and trim parameters and then hit ok. You then can do a edit/new,duplicate, rename and make the diameter any size you want. Post edited on 2004-08-05 10:21:17
Fri, Jan 11, 2008 at 1:05:05 AM | circular openings in concrete walls
dianajohn
I have found with older versions, that if the circle you are drawing is small then this error happens. Try drawing the circle larger than need. Revit Should create the hole. Once the hole is created, edit it to the size you need.
Best of luck
John A
Steel or concrete circular beams
Mon, Apr 20, 2009 at 3:56:24 PM
Dimensioning a concrete panel w/ openings in elevation view
Tue, Mar 25, 2008 at 3:07:22 PM
Making in place walls look like walls in plan
Tue, Aug 9, 2005 at 9:11:59 PM
Openings in (Structural) Walls Scheduling as Non-Bearing Walls
Thu, Feb 21, 2008 at 5:55:28 PM
Copy/Monitor Openings
Tue, Aug 9, 2016 at 3:41:46 PM
Page generation time: 0.6373
