43 Users Online (42 Members):
Forums >> Revit Building >> Technical Support >> Columns @ Angles
4 Posts No Rating |
I'm trying to create a covered walkway with angled columns. How do I set the columns to a certain angle? I've tried massing, and rotating in other views - no luck. Thanks in advance! Gerry
4 Posts No Rating |
-- Figured it out --
69 Posts No Rating |
Please share your solution with us :-)
4 Posts No Rating |
New > Family > Column > created 6" Dia w/ 1/4" thick wall thickness - tube - used the blend too; - 6" dia base, offset in 1/4", then changed to elevation view - set reference line for desired angle, dimension the distance from endpoint of top of angle @ desired height - switch back to floor view - edit top - move to the dimension - copy base... and there it is! HTH, Gerry
hidden columns |
Fri, Mar 26, 2010 at 10:53:36 AM
Showing columns from the floor above |
Mon, Jun 9, 2008 at 1:49:48 PM
Corner angles |
Sun, Apr 5, 2009 at 5:35:32 AM
Concrete Slab Edge Angles |
Wed, Dec 7, 2011 at 12:35:24 PM
13
recalcitrant columns |
Tue, Aug 3, 2004 at 7:38:46 PM
Members: | 2056530 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
