18 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Spiral Stairs
Hello Guys! I am trying to fit a set of spiral stairs in a 4' widex 16' tall area. but it seems a little impossible... when I set the base level and the top level constraints it gives me the total of risers for such stairs but the problem iis the radius of the stairs. it is bigger than the area I have for them...is there a way to make them fit in 4' wide and 16' tall? the only way I see that it can fit is by grabing the stairs starting point on sketch mode and spin it 1 1/2 full cycle but it wont' let me go past the starting point once I do the full cycle without taking me back to square one. does anybody know who to make it work or is it simply impossible? I appreciate your Help a lot ...I really do! thanks Sagir
----------------------------------- SAGIR |
you will find the answer for greater than 360 degrees rotation here http://www.revitcity.com/forums.php?action=viewthread&thread_id=2118 . this one may help with the diameter/radius problem http://www.revitcity.com/forums.php?action=viewthread&thread_id=6972 HTH
Edited on: Sun, May 27, 2007 at 8:10:15 AM
Spiral Stairs around a Central Post |
Sat, Apr 16, 2011 at 9:27:29 AM
Spiral Stairs |
Fri, Jul 4, 2008 at 1:34:57 AM
Residential Spiral Stair |
Mon, Feb 16, 2015 at 10:02:06 AM
Spiral stairs with small diameter |
Thu, May 6, 2010 at 6:53:26 AM
Real spiral stairs. |
Wed, May 20, 2015 at 2:21:32 AM
Members: | 2042240 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
