65 Users Online (64 Members):
Forums >> Community >> Newbies >> Grade Lines in Elevation view not showing
5 Posts No Rating |
When viewing my model in elevation view, the grade line where the site intersects the building wall does not show up. Its sort of like two intersection roof planes that do not show the intersecting line until you join the two roofs together. Since you cannot join a wall to the topography, how can you make the grade line show up in elevations?
Correct. I tend to draw the topography in section with a filled region and then turn off the topography. Purely because the topography generally doesn't display the way i want it to in elevation. This is caused by the cut of the topography showing the cut where the elevation is rather than where the building is.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
Grade Hatch in Elevation |
Wed, Aug 6, 2008 at 12:03:16 AM
Showing Grade in Elevations |
Wed, Apr 21, 2010 at 8:52:15 AM
View Name showing up in Elevation Tag |
Wed, Feb 29, 2012 at 6:53:36 PM
Lines in plan and elevation are only showing as dashes...HELP :'( |
Thu, Oct 30, 2014 at 7:37:41 AM
Lines not showing on elevation and cross section views |
Tue, Mar 12, 2013 at 7:43:57 AM
Members: | 2017179 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
