41 Users Online (40 Members):
Forums >> Revit Building >> Technical Support >> Spot Elevation tag
20 Posts No Rating |
I am attampting to utilize the spot elevation tag on my roof plan. I have a roof assembly that is rigid insulation over plywwod deck. I want the spot elevation to reference the top of the deck or even the under side of the deck. Currently I can only get the spot elevation tag to dimension to the top of the rigid insulation. Can this be done. Any help greatly appriciated.
When you go to place a spot elevation the options bar should have a reference level drop-down you can choose from. reit in 06, may not have, lol, snappy response eh?
The reference level drop down only refers to spot elevations "reference level"!
In plan views, you can only spot elevate the top surface.
oops misread, i just use the spot elevation command for the most part.
Spot elevation Tag and Insulation |
Wed, Jun 11, 2014 at 10:00:27 AM
Invert Elevation Vs. Spot Elevation |
Mon, Apr 20, 2015 at 2:09:11 PM
Spot elevation tag issue |
Mon, Jun 3, 2019 at 3:18:37 PM
ceiling tag to read as spot elevation (top or bottom elevation) (2017) |
Tue, Aug 28, 2018 at 10:51:10 AM
System Families: Spot Elevation Tag |
Thu, Jan 20, 2011 at 7:22:13 AM
Members: | 2022388 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
