65 Users Online (64 Members):
Forums >> Revit Structure >> Technical Support >> Column tags rotation
6 Posts No Rating |
Hi The drawings I do are basically towers so I need to show in fine detail to see the beams and columns. The drawings consist of multiple floors (15 less or more) all need special arrangement and 4 elevations. The thing is these elevations need to be turn 90 degrees counterclockwise on a sheet so that makes the column tags upside down. Is there a way to rotate these tags, like the parameter (keep readable) on text. If not it will be a good thing to have in the next version of Revit. Thanks
Beam & Column tags |
Tue, Jun 14, 2005 at 4:48:53 AM
Columns and Copy Monitor |
Thu, Jul 19, 2018 at 10:11:27 AM
DISPLAY COLUMN LABELS |
Wed, Sep 8, 2010 at 3:53:41 AM
Base Plates & Graphical Column Schedules |
Mon, Feb 22, 2010 at 11:51:01 AM
View Rotation on Sheet |
Thu, Jan 18, 2007 at 10:12:38 AM
Members: | 2022243 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
