120 Users Online (117 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> How to show overhangs as dashed lines on a floor plan
Wed, May 23, 2007 at 11:28:39 AM | How to show overhangs as dashed lines on a floor plan
terealva
I would like to be able to show overhangs on my plans as a dashed line without having to draw it. I know this is possible to achieve with range visibility. But I'm not sure how to accomplish it. Does somebody know how to do this?Thanks,Terealva.
Wed, May 23, 2007 at 12:29:39 PM | How to show overhangs as dashed lines on a floor plan
sdbrown
5 Stars: 3 Votes
adjust your view range so you see the object, then use the linework tool to change the lines to overhead, then return your view range to the original setting.  Note if the object is deleted or modified the lines may need to be re done.
Wed, May 23, 2007 at 9:23:46 PM | How to show overhangs as dashed lines on a floor plan
puzzle
4 Stars: 10 Votes
Go to the floor plan that you want to show the roof overhangs. Go to View Properties<Underlay<select level above eg Ceiling height. You may want to go to visibility setting and turn off gutters, fascias & roof surface pattern. Then use linework tool and pick the roof edge.
You could also Underlay the upper level then go to Visibility & change the roof to the line type you want.
Macca
Sunshine Coast
QLD Australia
How do I get to show lines dashed in plan view?
Sat, Oct 24, 2015 at 4:57:45 AM
objects above - dashed line
Fri, Oct 21, 2005 at 4:43:04 PM
Underlay as dashed lines 2012
Sun, Nov 24, 2013 at 9:26:02 PM
How to show structure below dashed
Tue, Jan 10, 2006 at 9:27:02 PM
11
Show ceiling/roof lines as hidden lines on floor plan
Mon, Aug 17, 2009 at 12:24:44 PM
Page generation time: 2.7263
