71 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Walls stop short of intended level - why?
Tue, May 22, 2007 at 3:55:15 PM | Walls stop short of intended level - why?
CrystalNanney
Hi, I am on Revit 8.1 and I've been using it about two weeks.  In some places where I have a floor, the walls below stop at the underside of the floor instead of continuing up to the actual level.  Once, I erased the floor and they fixed themselves.  Later, I tried it again and they didn't.  All my level offsets are zero, how do I fix this?
 Thank you kindly,
Tue, May 22, 2007 at 5:26:18 PM | Walls stop short of intended level - why?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
The walls tops are attached to your floor.  Typically when you draw a floor you'll usually get a prompt asking if you want walls that are under this floor to attach to it.
To attach or detach a wall.  Select it, then at the top status bar select attach (top or bottom radio button depending on which bit you want to attach) then select the element that you want it to attach to.  This is the same process for detach.
HTH.
Regards,
Chris.
Wed, May 23, 2007 at 8:36:32 AM | Walls stop short of intended level - why?
CrystalNanney
Thanks, that was so simple!  I'm so grateful for this forum.
short walls+phases problematic
Fri, Dec 16, 2005 at 7:15:17 PM
Walls won"t stop
Fri, May 3, 2019 at 1:50:47 PM
Hide Walls Below - New to Revit
Wed, Sep 3, 2014 at 8:13:23 AM
Hide top of walls
Tue, Apr 28, 2009 at 3:38:50 PM
Walls show up on Second Level plan
Wed, Dec 19, 2018 at 8:39:25 AM
Page generation time: 1.1532
