83 Users Online (81 Members):
Forums >> Revit Systems >> Technical Support >> I can not Get my device to attach to the ceiling on a linked architectural file
![supercadder Avatar](user_avatar/34579.jpg)
9 Posts No Rating |
I am using Revit MEP 2008. I have made a projector family and it gives me the NO symbol when I try to insert it into the ceiling plan of the linked architectural file. Any help, I have attached the projector family I created. Thanks
I haven't been lucky enough to be involved with much interdisciplinary collaboration on revit yet. However, I'd imagine you'd need to use the copy/monitor tool on the ceiling to create a linked duplicate of the ceiling in order to host your projector.
Regards,
Chris.
9 Posts No Rating |
I am not sure if that is it, The stock fixtures (light fixtures) connect to it just fine. The projector which I made from scratch will not. I eill try the copy/monitor tool again to make sure I got the ceiling level though.
![4.5 Stars: 25 Votes](/images/stars_4.5.gif) |
Many if not most of the stock fixtures in MEP are workplane based. This means that they do not need a 'host' to attach themselves to, just a plane which can be in the linked file. Your projector is 'ceiling' based which means that you need a physical ceiling in yur model in order for the projector to be placed since it needs the ceiling as a 'host'. I was able to place your projector just fine into a ceiling. Your answer may be to create a 'work plane' based version of the projector. The workplane based family is the default mode that should be used for all MEP content for this very reason.
Light fixture does not host to ceiling |
Mon, Feb 24, 2014 at 7:14:24 AM
Linking RCP to main architectural model |
Tue, Aug 5, 2008 at 2:52:30 PM
GETTING EXIT SIGN TO MOUNT IN CEILING |
Mon, Jan 25, 2010 at 10:01:23 AM
Attach MEP lights to Arch Grid |
Tue, Feb 9, 2021 at 8:26:08 AM
Linked Revit Model Sheets |
Fri, Apr 5, 2013 at 12:04:28 PM
Members: | 2022302 | Objects: | 22973 | Forum Posts: | 152200 | Job Listings: | 3 |
