79 Users Online (78 Members):
Forums >> Community >> Newbies >> room tags
6 Posts No Rating |
does anyone know how to make a room tag two lines for the name of the room and still have yet another line for the room number??? if you could help me out I would appreciate it! thanks!
Just setup a room tag so the room name parameter wraps after the required distance. Then move the number down so it allows enough room for when the room name is two lines. HTH.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
6 Posts No Rating |
mr spot, could you please walk me through that? please!? i'm trying to figure it out and i'm cussing at my cubical buddy...he just crawled under his desk and is sucking his thumb in the fetal position...haha, i'm totally kidding, but any help you could give i would appreciate it.
Edit your room tag family. Select the room name parameter, you'll see a crop box show. Adjust it to the desired length where you want it to start wrapping text. - good idea is to type in some sample text that you want to show on two lines. Then check to see the justification of your room name label. Most like it should be set to top and left aligned. Now move the number label down so it doesn't overlap your room name parameter. Either save the family over your old one (only if you don't want your old one) OR save as a new family with a new name. Then load it into your project and swap out the existing room tags for that one. HTH.
Regards,
Chris.
Mr. Spot, why not just edit an existing family room tag and just insert room number label below room name and save as? Here is a sample one
----------------------------------- VND |
OOOps,sorry i think i have misunderstood your question... but why why not just insert the comments label, in place of the name label (or both) with the number below? The comments label gives you two lines.
ROOM TAGS |
Fri, Jul 29, 2011 at 8:25:58 AM
Select room tags; copy rooms to new phase |
Thu, Jun 29, 2006 at 7:19:48 AM
Room Tags on Demo Plans |
Mon, May 9, 2022 at 3:23:12 PM
Want to see Room Tags but not Rooms |
Wed, Oct 5, 2016 at 11:37:51 PM
Vanishing room tags |
Tue, Sep 6, 2005 at 5:54:21 PM
Members: | 2058062 | Objects: | 23076 | Forum Posts: | 152250 | Job Listings: | 3 |
