74 Users Online (73 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Attaching Beams to a Round Structural Columns
Tue, Jan 4, 2005 at 8:04:40 PM | Attaching Beams to a Round Structural Columns
benbolivar
Does anyone know how to attach a beam to a round structural column so that it visually attaches to the core instead of being tangent to the surface of the column? The round column I use is 200mm in diameter. Thanks, Ben Bolivar
Sat, Nov 28, 2009 at 2:51:50 PM | Attaching Beams to a Round Structural Columns
irevitcoa
irevitcoa Avatar
-bump-
Mon, Nov 15, 2010 at 3:38:31 PM | Attaching Beams to a Round Structural Columns
mlarmand
Did you ever find an answer to your problem?  I am having the same issue.
Mon, Jul 15, 2013 at 8:26:16 AM | Attaching Beams to a Round Structural Columns
caddeva
Is't right ? please see the attachment...
if it's ok.... just drag the beam to centre of round column. it's works.
Attaching structural columns to beams - mitered joint?
Mon, Nov 15, 2010 at 3:37:44 PM
Beams won't intersect or close-up to Structural Columns. Solution ?
Tue, Oct 18, 2016 at 2:01:11 PM
Concrete Columns and Beams cuts through wall...
Mon, Feb 4, 2013 at 8:10:15 AM
Attaching Columns to Footers
Tue, Feb 24, 2009 at 7:34:29 PM
Walls and Structural Beams/Columns and Finishes
Tue, Jul 19, 2016 at 3:46:11 PM
12
Page generation time: 0.7835
