Forums >> Revit Building >> Technical Support >> Walkthough question. I'm sure an easy question to answer!
So how do I hide the number of frames in the upper left hand corner of my walkthrough? I don't want to show a walkthrough with the number of frames counting while I show it to a client... I'm sure you all know what I'm talking about I searched and didn't find anything. Thanks in advance.
LHAA Licata Hansen Associates Architecture Reno, NV USA |
Walk-thrus are meant to be exported. Go to File>Export>Walkthru I typically go to an .avi file which can then be played back in Windows Media Player.
the only soulution i have heard of is taking it into a third party package and editing it out there. have not checked to see if RAC2008 has a option to remove this P.S. What's wrong Tom, having a rough day HTH
Yeah I always export my walkthroughs as avi's but it still had the frame numbers in the corner but I guess I'll just have to use another program to edit the numbers out, not too big of a deal. Thats annoying that they didn't give you an option to do anything with the frame numbers... o well. =P Thanks guys
Just to clarify: Export a Shaded or Hidden Line walkthrough - you have the frame count Export a Rendered walkthrough - you don't have the frame count. Unfortunately from within Revit there is no way to turn this off and all you can do is edit the frames and remove the numbers afterwards. HTH.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
this is new in revit 9 onward right? revit 8.1 didn't have that frame count feature which I think is good...
----------------------------------- Life is never easy but nor it should be complex. Just stay simple |
Agreed with alec02 here. I have been using Revit 8.1 to do line, shaded and rendered walkthru. I cannot recall seeing the Frame Countdown. If this happened in 9.1 and 2008, I wonder why they want to do that as it can be very distracting. Thanks for highlighting this issue.
----------------------------------- G'day mate. I am migrating to Sydney, Australia. Looking for Revit Architect position. Any taker? Thanks. Kim Wong. |
Ok I'll create a rendered walkthrough instead I just wanted something quick for a meeting and thats why I just went with the shaded. Oh and your welcome KimWong. Thanks for the help Mr Spot and everyone.
15 Posts No Rating |
Hi, I've just started creating a fly-through in Revit 2009. I've exported it as hidden line and also as rendered as an .avi. The exporting went like a dream but each one has the frame count in the top left hand corner, and I'm wondering whether it can be removed from within Revit. If you there isn't an option within Revit, could someone please suggest how I could remove it in a third party software. I notice Mr. Spot said that rendered walkthoughs dont have a frame count back in 2007, have autodesk now added it to every type of exported walkthrough? cheers, J-P
Easy Question...Cant find answer.. |
Thu, Nov 30, 2006 at 11:04:55 AM
Walkthough decal |
Thu, Jan 14, 2010 at 1:48:56 PM
Workarounds |
Wed, Jan 25, 2012 at 3:47:46 PM
Revit 2011 test question |
Tue, Aug 7, 2012 at 10:49:46 AM
walkthough elevations |
Wed, Mar 29, 2006 at 5:12:05 PM
