43 Users Online (42 Members):
Forums >> Revit Building >> Technical Support >> corner mullions
21 Posts No Rating |
Could somebody please explain to me how corner mullions work? Thanks, Terealva.
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
What are you trying to do? They work where two curtain walls join. You can then apply a corner mullion on the corner and both adjacent panels will trim to the corner mullion. A normal mullion will not trim both walls.
Regards,
Chris.
1 Posts No Rating |
How can I modify the defaulty corner mullion profile in revit? Or Can I make new corner mullion? Thanks!
![5 Stars: 3 Votes](/images/stars_5.gif) |
There are a couple stock corner mullions and you can only modify the properties provided. My solution is to us a column family for corner mullions, that way I can control the shape I want.
Corner Mullions |
Fri, Dec 6, 2013 at 11:05:58 AM
Horiz mullions wont clean up because of angled corner mullion |
Wed, Oct 1, 2014 at 8:43:20 AM
corner mullion storefront [ 1 2 ] |
Sun, Jun 28, 2015 at 5:33:52 PM
15
cleanup horizontal mullion at corner mullions, again.... |
Wed, Jan 8, 2014 at 11:14:49 AM
Curtain Wall Corner Mullions |
Thu, Nov 10, 2005 at 11:24:13 PM
Members: | 2022345 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
