61 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> Fill Patterns
21 Posts No Rating |
Is it possible to create a fill pattern that looks like the pattern I've attached? If so, how can that be created? Thanks,Terealva
Purchase and use HatchKit to create custom patterns.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
1 Posts No Rating |
There has to be another way?
There is another way. AutoCAD hatch patterns are described in a txt file by telling the pen when to write and in what direction. Below is a standard description. *AR-B816, 8x16 Block elevation stretcher bond 0, 0,0, 0,8 90, 0,0, 8,8, 8,-8 If you can learn this process, you could write your hatch file pattern or perhaps you can find someone to do this for you. Obviously there is a cost one way or another.
Edited on: Wed, Jul 25, 2007 at 9:51:28 AM
Perpsective Fill Patterns |
Mon, May 10, 2010 at 6:12:50 PM
Fill Patterns |
Mon, Mar 10, 2008 at 6:40:09 AM
create/ convert hatch patterns (.pat) to revit fill patterns |
Tue, Jun 2, 2015 at 11:29:00 AM
Fill patterns, where are they? |
Tue, Mar 31, 2009 at 10:11:29 AM
Wall Fill Pattern question |
Tue, Oct 23, 2012 at 8:39:37 AM
Members: | 2042244 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
