108 Users Online (105 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> curtain walls in legends
Mon, May 21, 2007 at 11:45:44 AM | curtain walls in legends
jrosenwald
it seems curtain walls can not be accessed by a legend (or at least an elevation view). Is there a way to set up an elevation of a curtain wall that is not merly detail lines?
Mon, May 21, 2007 at 1:21:29 PM | curtain walls in legends
jterrell
3 Stars: 5 Votes
create an elevation of the wall and turn off everything but curtain panels and mullions in the view
Mon, May 21, 2007 at 1:44:46 PM | curtain walls in legends
jrosenwald
that would work but if the curtain wall were moved or deleted, I would have to update my dimensions. I would also only be able to have one elevation per view. What is nice about the legend is the ability to position multiple elevations in relation to one another.
Mon, May 21, 2007 at 4:34:42 PM | curtain walls in legends
markowings
What we've done is create a new elevation key and elevation called glazing elevation. We then place this elevation key outside the crop region and drop the generated view to the sheets. We then turn everything off in the view except for the curtainwalls.
This works fairly well; however, you really need the new crop annotation tool in 2008 to hide all these extra elevation keys from showing up on the sheets.
We created a multi-category tag that we tag the windows and the curtainwalls with in the plans so that they are keyed alike. The glazing elevation keys are not shown on our printed plans.
Hope this helps.
Mon, Apr 14, 2008 at 9:49:09 AM | curtain walls in legends
jmqrsq
5 Stars: 3 Votes
what do you mean "elevation key" exactly?
Mon, Apr 14, 2008 at 10:10:11 AM | curtain walls in legends
markowings
Actually, I meant to say "elevation tag", not key sorry.
Mon, Apr 14, 2008 at 10:20:32 AM | curtain walls in legends
jmqrsq
5 Stars: 3 Votes
Gotcha. I am doing this now actually. But the Elevation tags wont print in the final documents as long as you have that option checked when printing.
Mon, Apr 14, 2008 at 11:29:08 AM | curtain walls in legends
markowings
Correct, but we wanted an elevation tag that would be the same for curtain walls and windows. We created a custom multi-category tag that works with both component's shared parameters. We then just hide the elevation tags used to generate the curtain wall elevations.
Tue, Apr 15, 2008 at 7:15:30 AM | curtain walls in legends
jmqrsq
5 Stars: 3 Votes
Good idea. would you mind if i took a look at how you setup you rmulticategory tag? we havent delved into that a lot yet here and I know it would help us with some of our other ongoing issues. If you dont mind I would like to download your tag and check it out.
Tue, Apr 15, 2008 at 8:42:41 AM | curtain walls in legends
markowings
Sure. I've attached it for your use below. Again, This way we can tag windows, curtain walls, and storefronts with a similar tag. We use CW-XX for curtain wall, SF-XX for storefront, etc.
I might add that we are trying different ways on different projects, but this appears to work well.
Tue, Apr 15, 2008 at 9:01:24 AM | curtain walls in legends
#11
jmqrsq
5 Stars: 3 Votes
Awesome! Thanks! I will take a look at it today. Did you see Revit 2009 is available for download now?
Tue, Apr 15, 2008 at 9:06:43 AM | curtain walls in legends
#12
markowings
Man, I've been checking that site every 20 minutes for weeks. I guess I have a new task for today!
Tue, Apr 15, 2008 at 2:30:14 PM | curtain walls in legends
#13
jmqrsq
5 Stars: 3 Votes
Looks like some nice fixes/enhancements. Menatl ray has me excited. I hope its 1000% better than Accurender.....
Mon, Sep 1, 2008 at 11:47:11 AM | curtain walls in legends
#14
mestresdomenech
I've been looking for the same...I'll will use this system by now although I don't thonk is perfect...
I'm stil missing the possibility of having curtain walls and interior glass wall divisions in a legend. It should be incorporated in 2010 version!!
Tue, Feb 23, 2010 at 9:50:10 AM | curtain walls in legends
#15
arkjalomo
i have the same problem with curtain walls in legends...and iv read all about, i download the tag attached in this thread...but i dont understand how to use it...could some one help me?...
curtain system legends HELP!
Sat, Jun 14, 2008 at 3:56:06 PM
Curtaing walls in Legends????
Thu, Feb 25, 2010 at 2:27:33 PM
Curtain Walls + Door Legends
Thu, Dec 7, 2006 at 1:30:40 PM
Angled Curtain Walls - fillets and nested
Thu, Apr 23, 2009 at 5:42:48 PM
Curtain walls
Mon, Nov 7, 2011 at 10:28:34 AM
Page generation time: 0.5940
