136 Users Online (133 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> The Studio >> Need a brick arch for rendering. Any suggestions or sources?
Tue, Jan 4, 2005 at 10:54:16 AM | Need a brick arch for rendering. Any suggestions or sources?
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
I need the arch to be made up of brick soldiers that radiate around the arch radius center point. Would making a sweep using a brick soldier pattern work? Can you apply a sweep in a curve at an elevation and expect the soldier to stay perpindicular to one edge of the sweep? Sounds like too much for accurender.
Tue, Jan 4, 2005 at 12:19:49 PM | RE: Need a brick arch for rendering. Any suggestions or sources?
middleton
it sounds to me like the answer is not in textures (though one could create a new texture that would apply....it might not be worth the trouble). try creating a brick family that has the approriate texture. then, in your project, array the new brick family around the arch. if the geometric distinction is not enough for your render, you can then create a sweep aroung the arch that would represent the mortar, and texture appropriately. im sure there is a better, more efficient way, but this method has worked for me before. let me know if it works for you, and good luck.
Wed, Jan 22, 2014 at 5:35:29 AM | Need a brick arch for rendering. Any suggestions or sources?
JRPcad
Try the family here: http://essentialbim.com/product/brick-arch/
It works a treat and is very flexible and easy to align to your window width, you can also adjust lots of parameters to get the look you want.
Edited on: Wed, Jan 22, 2014 at 5:36:11 AM
For Architectural Services visit www.jrpcad.co.uk
Brick Arch Around Window
Sun, May 3, 2009 at 6:21:16 AM
Brick Arch Family - Do you have one??
Tue, Apr 12, 2016 at 10:35:55 AM
Rendering light sources within a custom curtain wall panel
Mon, Sep 26, 2011 at 2:59:10 PM
Window with different head height on inside and outside
Wed, Sep 3, 2008 at 11:59:17 AM
Flat (Jack) Arch w/ Keystone 2008
Mon, Mar 17, 2008 at 4:08:41 PM
Page generation time: 1.5057
