44 Users Online (42 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Revit 2008 Surface Pattern isuues
Fri, May 18, 2007 at 6:12:06 PM | Revit 2008 Surface Pattern isuues
suntzu61
OK I am running into something wierd with Revit 2008 and our windows in elevation views.
The Probelm:
When we print our elevations that have windows with a solid fill pattern for the glass, we get gaps in the fill pattern and bleeds onto other columns and walls from the windows. We have tried multiple PC's and different printers..Including PDF.
Has anyone seen this yet and is there a way to fix it?
Thanks
Jared
Wed, May 23, 2007 at 2:19:53 PM | Revit 2008 Surface Pattern isuues
rkitect
rkitect Avatar
4 Stars: 29 Votes
I have not had this problem with RA2008, but have not used fill patterns extensively yet.
I would check to make sure there isn't a material in the columns and walls that is being affected when you change the glass fill pattern.  Also, try using the paint bucket on the walls and columns and walls to recover the correct material on them.
Let us know what you find out.
Surface Pattern from family to project.
Mon, Feb 18, 2008 at 4:35:40 PM
Surface pattern move/align/adjust problems [ 1 2 ]
Thu, Sep 17, 2020 at 10:29:33 AM
19
Surface pattern
Mon, Sep 10, 2007 at 11:18:01 AM
SURFACE PATTERN LINE WEIGHT
Fri, Mar 28, 2014 at 2:30:00 PM
Hiding Surface Pattern For Specific Wall Material
Thu, Feb 21, 2008 at 10:47:29 AM
Page generation time: 3.1240
