Forums >> Revit Building >> Technical Support >> I SEE 1ST FLOOR FROM 2ND FLOOR PLAN...WHY IS THAT?
43 Posts No Rating |
For some reason When I double click on the second floor plan, I see the first floor plan. How can i fix this?
Matias Santini |
I just noted that some walls are unconnected on the top constrain.....but no matter if I change it to the second floor, still having the same issue.
Matias Santini |
the first thing to check is the properties for the view and set the Underlay to "none" HTH
THANKS!!!
Matias Santini |
1 Posts No Rating |
thanks!!! this helped me too!! it was driving me crazy.
I had the same issue last week and I had to re-draw the wall showing on the socnod floor. now I know.......hehe
Matias Santini |
1st floor to 2nd floor |
Sat, Apr 7, 2012 at 10:01:21 AM
Display Room Names for Double Volume Spaces on 2nd Floor Plan |
Mon, Mar 18, 2013 at 10:46:30 AM
2nd flr walls not lining up with first floor walls |
Wed, Jun 16, 2010 at 2:20:43 PM
my 1st floor plan has not detail |
Fri, Nov 23, 2007 at 10:33:33 AM
Show above floor plumbing on 1st floor Framing |
Tue, Feb 19, 2008 at 3:29:39 PM
Members: | 2101398 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
