60 Users Online (58 Members):
Forums >> Revit Building >> Technical Support >> Selecting Elements in Revit
![3 Stars: 2 Votes](/images/stars_3.gif) |
Is there a way to select all the elements in a specific view. The Select All Instances chooses every element in your file. There a time were I have multiply elements on one level that needs to change. It would be nice to be able to grab them all quickly and change them. I know with object you can Isolate Category and grab them all that way. But with annotation you cannot always do that. Specifically I am talking about Room Tags. I like to be able to change my room tag to show area when I am working but then I need to change them to just show the room number when I am done. Well if I Select All Instances it changes the Room Tags in my presentation views that just say the room name. So Right now I have to select each tag individually and change them and that is annoying when you have lots of rooms. If I try Isolate Category it isolates the room and not the tag. Back to my original question is there a way to only Select All Instances in view only. Thanks for the help
![coreed Avatar](user_avatar/14568.jpg)
select all the elements and then use the filter button in the options bar to remove un-wanted elements HTH
Thanks alot I have been using Revit for awhile now and have not paid any attention to that button.
Grouped elements not selecting |
Fri, May 22, 2009 at 1:23:14 PM
2015: selecting elements in link |
Tue, Nov 18, 2014 at 1:17:26 PM
12
Selecting all elements |
Mon, Dec 19, 2005 at 5:36:24 PM
Selecting-De-selecting objects. |
Fri, Nov 25, 2005 at 10:12:01 PM
Elements don't appear highlighted when selected...always need to refresh!! |
Thu, Jun 30, 2011 at 6:03:51 AM
Members: | 2019273 | Objects: | 22958 | Forum Posts: | 152182 | Job Listings: | 3 |
