85 Users Online (84 Members):
Forums >> Revit Building >> Technical Support >> HELP - Converting Components and Elements from lower version numbers
![MongooseST7 Avatar](user_avatar/16379.jpg)
8 Posts No Rating |
I have recently upgraded to Revit Building 9.1. I have also downloaded from th Autodesk website various components and elements formed in versions below 9.1, i.e. ver 8 and 9. I have unzipped them into the respective files to be used in my projects. When I go into those files to insert them in it states it was saved in an earlier version and cannot be retrieved. I assume that the utility that came with the Version 9.1 disk the Content Batch Upgrade Utility below takes care of this ? Now I go and run it as per the below directions but nothing happens I do drag the Upgrade_RFA.txt into the Revit9.1 icon on my desktop and the same result, nothing, I cannot convert these components and elements made from lower versions. Any Help would be approeciated This is a Content Batch Upgrade utility. Using this utility, you can automatically upgrade Revit family files to the current file format of Revit. Instructions: Run Upgrade_RFA.bat first to create a list of all RFA files in the current folder and all subfolders. Then run the journal file Upgrade_RFA.txt by dragging it onto your Revit shortcut.
![4 Stars: 13 Votes](/images/stars_4.gif) |
How about downloading the library content for 9.1? I believe the best way to get at the content, seeing it is virtually impossible to find on their website is in Revit itself go to File>Load from Library>Load family and in the top right corner is a "Web Library" tab.
revit latest version cannot be save to a lower version |
Wed, Apr 27, 2011 at 10:00:25 AM
converting |
Tue, Oct 12, 2010 at 7:05:20 AM
Deposition to a lower version |
Wed, Sep 19, 2012 at 8:01:38 AM
Lower level elements |
Tue, Nov 27, 2012 at 10:53:43 AM
8.1 components to Revit 8 |
Fri, Mar 10, 2006 at 2:13:17 PM
Members: | 2022428 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
