96 Users Online (94 Members):
Forums >> Revit Building >> Technical Support >> Mitered corners
41 Posts No Rating |
I need to build a component that turns a square corner into a mitered corner. The hard part is cutting out the existing wall. My original was a wall based corner but it only cut one of the two walls and was a real hastle to copy up to the next floor, would not find host crap. I am using a generic right now but have to go back and split and delete wall ends manually somtimes 100's per floor. Can't seem to get Void to cut the walls. HELP. Thanks
![4 Stars: 13 Votes](/images/stars_4.gif) |
My apologies if I'm not following 100%. It sounds like you're trying to do something similar to a corner window? I got this corner window family from here in the downloads http://revitcity.com/downloads.php?action=view&object_id=3635 I downloaded it and tried it and at first I couldn't get both walls to cut. But I tried again and got it. You have to place it just right. Mine was placed just a touch towards the outside of the exterior part of the wall. Hope this helps. If not quite what you were talking about, you could post a screenshot and the family.
Here is one i created. Hopefully i uploaded a version that didn't have errors. Let me know if there are errors with it. http://www.revitcity.com/downloads.php?action=view&object_id=1861
Regards,
Chris.
I agree might be posible to make a window work. Tried it once don't have time to study it right now but will later it is a reverse of what I am after. Here is what I am using. It is 2 bends in a peice of dimond plate. a 4" at the top and 2-12" at the bottom. I need to be able to place and clean up thousands of these each day, and trimming maually is not cutting it: Punny huh.
MITERED CORNERS |
Wed, Dec 10, 2008 at 9:23:26 AM
Mitered beams at will not stay mitered when I connect a end shear plate |
Fri, Sep 9, 2016 at 10:34:18 AM
Turning Vanes in Mitered Elbows |
Fri, May 30, 2008 at 2:42:04 PM
Glitch with mitered steel beams and ading a shear plate. |
Mon, Sep 5, 2016 at 10:44:39 AM
Can you make wall joins Miter by Default? |
Tue, May 20, 2014 at 10:42:05 AM
Members: | 2017035 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
