48 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Wishlist >> Better stacked wall editability
Wed, May 16, 2007 at 2:29:59 PM | Better stacked wall editability
tim1424
It would also be great if we could edit a specific wall type of a stacked wall in the stacked wall properties box.  As it is now, you have to go to the original wall type of one of the walls that make up the stacked wall and then edit it.
This becomes frustrating while working in section because you have to highlight the stacked wall to get the wall properties box to come up.  Then if you want to edit one of the wall types of the stacked wall you have to navigate to that wall which inevitably changes the entire wall you were working on in section.  Then you realize you are an idiot and have to cancle the command, go into a plan view, select the wall command, select properties, find the wall you want to edit, edit it, then go back to the section, then look and see if the changes you made were correct.  Errr!
Anyone else have this issue or is it just me??
Wed, May 16, 2007 at 5:54:41 PM | Better stacked wall editability
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Good point...
Regards,
Chris.
Fri, Jun 1, 2007 at 8:13:36 AM | Better stacked wall editability
sdbrown
5 Stars: 3 Votes
From your wall section you can use the TAB key to select one wall in the stacked wall and edit it. You don't have to do what  you say.
stacked wall line visable on the wrong side?
Wed, May 6, 2009 at 10:51:58 AM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed
Thu, Jan 24, 2013 at 8:06:06 PM
Scheduling of Stacked Walls
Tue, Aug 18, 2009 at 2:16:01 PM
Breaking apart a Stacked Wall Issue
Wed, Mar 11, 2009 at 12:03:44 PM
Staggered Stacked Wall Join Problems
Tue, Oct 14, 2008 at 12:50:52 PM
Page generation time: 0.6813
