120 Users Online (119 Members):
Forums >> Revit Building >> Technical Support >> Lost Import
3 Posts No Rating |
Sometimes if an imported file (cad) is not linked (current view only) it can easily become lost when that particular view is deleted or its visibilty midified. the instance is still int the system yet its difficult to find if you dont know where it was originally placed. Is there an easy way to locate an imported instance so it can be deleted? No options are available form manage links or visibility/graphics to select the instance in question (as far as i can tell). thanks
![rkitect Avatar](user_avatar/4651.jpg)
![4 Stars: 29 Votes](/images/stars_4.gif) |
This is where it is good to know what version you are using. In Revit Architect 2008 you can just right click on the link in the Project Browser and 'Select All Instances' to have it highlight. In anything earlier, I never knew of a way to locate links once they were in a view. If I lost one, I just deleted it and made sure I selected manual placement next time so I know where it goes. Good luck and let us know what you find.
Import SAT file |
Fri, Nov 30, 2012 at 9:42:19 AM
import to revit from autocad |
Sun, Mar 31, 2013 at 11:37:12 AM
LOst Title shhet |
Fri, Nov 13, 2015 at 4:08:01 PM
recovering lost files |
Tue, Sep 2, 2014 at 1:28:11 PM
Importing SAT files |
Tue, May 22, 2007 at 9:09:20 PM
Members: | 2017040 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
