67 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> how to copy a schedule format or layout to other projects
Mon, May 14, 2007 at 6:13:40 PM | how to copy a schedule format or layout to other projects
hgm
After I created a template for my projects (and have started many projects) I relized that the window and door schedules needed to have different fields etc.  I have edited the fields and filtering on my schedules.  Is there a way to copy this new schedule format into all of the projects that I have already started.  I have tried using "File" > "Transfer Project Standards" but it doesn't apear that  "schedule format or layout" is listed as part of the project standards.  Similarly I created a new numbering format for my sheets. Can sheet number and names be copied or transfered to another project.
Tue, May 15, 2007 at 11:44:25 AM | how to copy a schedule format or layout to other projects
hgm
I am using Revit Building 8,  maybe this issue has been solved in newer versions.
Tue, May 15, 2007 at 12:39:39 PM | how to copy a schedule format or layout to other projects
TomDorner
4.5 Stars: 25 Votes
In version 8 the only way to copy a schedule from one project to another was to place the schedule on to a sheet in project A and then copy paste it from the sheet in project A to another sheet in project B.
In 9.0 and above you can now use the 'Insert from file' command.
Sheets can only be added one at a time in 8.0. In 9.0 and above you can again use the 'Insert from File' method or develop a custom API application.
Edited on: Tue, May 15, 2007 at 12:40:04 PM
Tom
www.reviteer.com   http://twitter.com/Reviteer
Common Unit layout to different buildings / projects
Thu, Aug 15, 2013 at 7:28:03 AM
Schedule format
Mon, Mar 5, 2012 at 2:33:51 PM
Export Schedule into PDF format
Wed, Sep 2, 2009 at 12:08:19 PM
revit schedule in vertical format
Tue, Jul 14, 2009 at 4:53:13 AM
Mon, Jul 13, 2009 at 6:52:46 AM
Page generation time: 1.0917
