71 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> rendering trees transparent
Fri, May 11, 2007 at 2:04:18 PM | rendering trees transparent
jrosenwald
is it possible to render trees transparent?
Fri, May 11, 2007 at 3:16:18 PM | rendering trees transparent
ArchWestCY
4.5 Stars: 7 Votes
How are you at Photoshop?  I can't think of an easy way to do this in Revit.  The plant materials in Accurender don't have a transparancy setting (that I could find).  Here's what I recommend.  Render your scene without trees.  Then render the same scene, same view, same everything, but with your trees turned on.  Then in Photoshop copy the w/trees rendering on top of the w/o trees rendering.  Then adjust the transparancy of the layer that has your trees on it.
I use a technique similar to this to add lines to my renderings.  First I render the scene, then I change the view to Hidden Lines and Export Image.  Using the magic wand (in Photoshop) I select and erase the white background leaving only the Linework.  I copy the Hidden Lines image on top of the Rendered image and set the transparancy of the Hidden Lines layer to about 40%.  This gives you a great rendering with lines that pop out and define your building.  I have done this with trees in the rendering and turn the trees off for the hidden line view, this defines the building edges behind the trees.
Give this a try if you use Photoshop.  I think that you will be happy with the results.
ArchWestCY
Fri, Mar 21, 2008 at 5:55:09 PM | rendering trees transparent
mhans
3 Stars: 10 Votes
Alternatively,  why not render your trees with fewer or skinner leaves? Copy any tree and using plant editor under plant library, edit leaf, opacity map. It doesn't look artistic but gives me what I need...to show the building.
Motto: "No Post left behind"
Mon, Mar 31, 2008 at 2:57:40 AM | rendering trees transparent
JustinT
Another way is to create your own artistic trees etc. I have made my own up using basic solids to give a conceptual feel and then applied a transparent material to the render...works quite well
 Justin
www.revitup.co.za
Sun, May 4, 2008 at 2:08:53 AM | rendering trees transparent
sharath
one more thing u can do is u can make it half tone in vsisbility graphics and also set it transperent...
search http://revittut.blogspot.com/ for more help
Wed, Oct 10, 2012 at 4:06:38 AM | rendering trees transparent
albionarchitect
On revit 2013 it's not a problem to set transparency on trees by overriding view settings of eth element or planting category. http://www.archigrafix.com/revit-trees.html is a good example of the effect of doing that.
Transparent Trees
Fri, Mar 21, 2008 at 10:03:10 AM
rendering trees as semi-transparent
Thu, Aug 7, 2008 at 9:18:16 AM
rendering trees in winter???
Tue, Dec 14, 2010 at 5:46:54 AM
Rendering Trees in Revit 2010
Wed, Apr 27, 2011 at 2:53:38 PM
Revit 2012 problem rendering RPC trees
Tue, Sep 6, 2011 at 5:26:08 AM
Page generation time: 0.4026
