89 Users Online (86 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Rotating Drawing Title on Sheet
Fri, May 11, 2007 at 1:07:05 PM | Rotating Drawing Title on Sheet
revitrae
I needed to rotate a view on a sheet, but the tag stays attached and rotates with it. How can I rotate the drawting tag seperately?
 Thanks
 Rae
Fri, May 11, 2007 at 1:21:03 PM | Rotating Drawing Title on Sheet
coreed
coreed Avatar
4 Stars: 16 Votes
this was posted by Mr. Spot in a previous posting, sounds like what you want to do
"EASIEST WAY: PLACE VIEW ON SHEET. ACTIVATE THE VIEW. SELECT THE CROP REGION. ROTATE THE DESIRED AMOUNT. NOTE THE VIEW ROTATES AND THE CROP REGION REMAINS THE SAME. THIS ALLOWS YOUR VIEW TITLE TO REMAIN HORIZONTAL."
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Sep 14, 2009 at 4:43:45 PM | Rotating Drawing Title on Sheet
SteveB
3.5 Stars: 5 Votes
2 years after you posted it... brilliant!
Mon, Sep 14, 2009 at 4:58:38 PM | Rotating Drawing Title on Sheet
Bronsart
Good thing you posted SteveB... I just learned something new.
Mucho Thanks!!!
Mon, Sep 14, 2009 at 5:01:39 PM | Rotating Drawing Title on Sheet
SteveB
3.5 Stars: 5 Votes
the "search forums" function finds all kinds of good stuff.
Rotating Views on Sheet
Tue, Jan 19, 2010 at 12:30:56 PM
Rotating Views On a Sheet [ 1 2 ]
Tue, Jun 17, 2008 at 12:49:47 AM
18
Rotating Viewports without rotating title
Wed, Apr 22, 2009 at 10:52:59 PM
Sheet´s Tags
Tue, Jun 19, 2007 at 2:17:33 PM
How to link a Revision Schedule on Title sheet with Title Block
Fri, Jan 11, 2013 at 7:26:27 AM
Page generation time: 0.6467
