41 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Exposed Joists in RCP
Fri, May 11, 2007 at 12:30:22 PM | Exposed Joists in RCP
Detour
1 Stars: 1 Votes
I am trying to show the roof joists in the areas of the rcp that have no ceiling.  I have adjusted the view planes but that hasn't worked.  Any suggestions?
Thanks, Paul
Fri, May 11, 2007 at 2:42:54 PM | Exposed Joists in RCP
TomDorner
4.5 Stars: 25 Votes
Is the category you used for your joists on in the view?  If you used structural components, you probably have to set your view resolution to Medium or Fine as most structural components only have a 'stick' view at course resolution.
Tom
Fri, May 11, 2007 at 2:57:45 PM | Exposed Joists in RCP
Detour
1 Stars: 1 Votes
Thanks for your reply.  I didn't have the structural framing check in the view graphics.  There are so many different places to do things in Revit it can be a little confusing at times.  Can you suggest any good books to help in the learning process.
Fri, Nov 30, 2007 at 9:56:34 AM | Exposed Joists in RCP
L2THAP
i'm just trying to add an exposed beam in my reflected ceiling plan.  can any one help.  i just started using revit.
Exposed Roof Deck_Tag with Height
Tue, May 31, 2016 at 3:59:37 PM
Ceiling tag for exposed structure
Mon, Oct 8, 2007 at 11:13:27 AM
Can't see my roof structure in my RCP
Wed, Oct 10, 2007 at 2:44:20 PM
Sloping joists to the roof deck
Mon, Apr 4, 2016 at 11:21:15 AM
joists
Thu, Oct 11, 2007 at 4:43:14 PM
Page generation time: 1.1953
