39 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> unjoining geometry
Fri, May 11, 2007 at 5:07:42 AM | unjoining geometry
Marc9999
hi,
i'm trying to show concrete columns within my model, some of which are within the wall construction.  The columns have a concrete hatch which when i place within a wall structure, change to the same hatch as the wall.  I have unjoined the geometry which overcomes the problem, however the column is hidden by the wall structure is there a way of ensuring the columns overide the walls (ie wall trims around the column)?
hope thats understandable!
cheers
marc
Fri, May 11, 2007 at 5:52:13 PM | unjoining geometry
framerman
4 Stars: 13 Votes
Sounds like you might have to edit the wall joins or separate the wall into 2 depending on how your column is in there. Is it hidden behind the wall, but you want it to still show up in plan view or cross section? If you could take a screenshot, it would clear it up better.
geometry memory size
Fri, Mar 27, 2009 at 11:28:05 AM
Cut / Join - Geometry (api)
Tue, Jul 29, 2008 at 2:07:19 AM
VOID FORM says there is no geometry to cut.... [ 1 2 ]
Wed, Dec 17, 2008 at 12:52:27 PM
19
Diagonal End of Wall - Void + Cut Geometry not working
Fri, Aug 30, 2013 at 3:25:08 AM
Rotating Symbol geometry without rotating leabel
Wed, May 6, 2009 at 8:33:58 AM
Page generation time: 0.2440
