80 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Model Text and Curved Walls
Thu, May 10, 2007 at 5:00:02 PM | Model Text and Curved Walls
katiea
How does one put model text on a curved wall?
Thanks!
Mon, May 14, 2007 at 2:07:44 PM | Model Text and Curved Walls
rkitect
rkitect Avatar
4 Stars: 29 Votes
Very carefully, so that they don't break when you bend them... Winking
One letter at a time is what I usually do.  Then rotate and position the letters to make it look like it is bending with the wall.  I have not tried using a curved reference line as the work plane though (not sure that's even possible).
HTH!
Thu, May 17, 2007 at 8:53:34 AM | Model Text and Curved Walls
robert
i have used a tangent ref plane as well and typed the full word along that but below the actual level
than type individual letter above it.i find it helps a bit to compere the spacings a bit,
before moving and rotating, please remember to disjoin text.
a bugger of a thing,  should be possible to apply directly
what about text on plan along an arc?
i can not find a way to do this unless as above and group it to keep it together.
revit must have been conceived by engineers who only think in straight lines
 robert.
Fri, May 18, 2007 at 9:29:50 AM | Model Text and Curved Walls
rkitect
rkitect Avatar
4 Stars: 29 Votes
Err.. I was talking about how I put letters on a curved wall, meaning in plan. It appears as though a similar method is used in both elevation and in plan, however.
SELF-TAUGHT NEWBIE: How to put model text on curved walls & 2 other questions?
Fri, Feb 27, 2009 at 11:21:33 AM
Curved Model Text
Wed, Feb 8, 2006 at 3:34:25 PM
Curved Model Text
Fri, Apr 5, 2013 at 2:10:34 PM
13
Model Text on Curved Wall
Tue, Dec 21, 2010 at 7:58:21 AM
Wed, Dec 8, 2004 at 2:20:21 AM
Page generation time: 2.3168
