17 Users Online (16 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> how do i - put in roof windows? see images
Thu, May 10, 2007 at 3:17:07 AM | how do i - put in roof windows? see images
samov
Hello.... i want to use these kind of windows in a roof?! (one manufacturer is velux)
thank you
Edited on: Thu, May 10, 2007 at 3:17:44 AM
23161_2dd27984-013c-45f8-8ecb-6c48757de76f1408STI424x238.jpg23161_living1370L.jpg23161_casavelux.JPG
Thu, May 10, 2007 at 5:07:30 PM | how do i - put in roof windows? see images
framerman
4 Stars: 13 Votes
I would make a generic roof based family for those. You should be able to change it to a window category after that if you need it to be.
Fri, May 11, 2007 at 6:12:57 PM | how do i - put in roof windows? see images
samov
could you be specific... i have some experience with revit... but apparently not enough.
i've found a temporary solution. making a mass element and making a curtain wall on one of it's sloped faces...
any TRUE solution?
Fri, May 11, 2007 at 7:35:38 PM | how do i - put in roof windows? see images
framerman
4 Stars: 13 Votes
This is a true solution. You go to file>new>family and pick generic roof based family. make your skylight you want using the modeling tools. Don't bother with the mass stuff.
when you are finished with the model, you can leave it if you like as a generic family, OR if you want to change it to a window family that will base itself on the roof, you can change the family category by going to
settings>category and parameters
and change it from generic to window. when you import your family into your project it will depend on your category as to where to find it to start the command. Window if you change it to a window family, or component if you leave it a generic family.
I just made a quick simple extrusion on the roof along with an opening to show you the start of how to do this. If you still need help, post back or you can email me also
Hope this helps.
Edited on: Fri, May 11, 2007 at 7:36:14 PM
Sat, May 12, 2007 at 2:56:20 AM | how do i - put in roof windows? see images
samov
OH MY GOD....
My understanding of revit has leaped 1 year ahead...
THANK YOU...
My best wishes,
samov
Sat, May 12, 2007 at 6:28:31 AM | how do i - put in roof windows? see images
framerman
4 Stars: 13 Votes
You are very welcome. Happy Reviting!
Error in the number of images in the Gallery...
Wed, Jul 16, 2008 at 4:43:03 PM
help asap!! roof and windows!!
Thu, Feb 1, 2007 at 6:44:37 AM
Rendering Images for vertical metal wall panels and standing seam roof?
Wed, Apr 19, 2006 at 9:13:39 AM
How can I place a windows ina roof?
Sun, May 10, 2009 at 6:54:07 AM
Rendering images from the internet
Mon, Jun 20, 2011 at 12:20:16 AM
Page generation time: 1.2267
