62 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> DIMENSION QUESTION
Wed, May 9, 2007 at 9:54:52 AM | DIMENSION QUESTION
kcw983
I am trying to place some swing tie dimensions on a site plan. I cannot figure out how to get a dimension from 1 point to another when the points are not aligned or parralel. How can I dimension 2 random points?
Thanks
Wed, May 9, 2007 at 11:37:29 AM | DIMENSION QUESTION
In real life, two lines tahat are not parallel can not be dimensioned because the dimension changes with where you are measuring from....  so we can never really do that.  Instead, we pick a line (plane) at a defined point that intersects both lines and dimension from those intersections.  In REVIT, you can mark those intersections with small parallel lines.   Remember that when you dimension like this, you still need a corresponding dimension perpendicular to your dimension string that shows where your reference plane is.  Otherwise, you dimension is meaningless.
Wed, May 9, 2007 at 9:35:52 PM | DIMENSION QUESTION
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You can dimension from any two randow points providing you are actually picking "points" and not faces.  Use your tab key until you pick the point.
Regards,
Chris.
Dimension Question
Wed, Nov 23, 2011 at 11:41:34 AM
"Simple" dimension question?
Fri, Feb 29, 2008 at 9:48:32 AM
Prefix in dimension style
Thu, Dec 16, 2010 at 9:15:11 AM
Question about Dimension Linetype
Fri, Oct 19, 2007 at 7:20:43 AM
Revit Boxed Dimension
Tue, May 8, 2018 at 8:24:43 AM
Page generation time: 1.8681
