82 Users Online (81 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Glass Curtain Wall doors
Tue, May 8, 2007 at 12:01:44 PM | Glass Curtain Wall doors
hkcea
4 Stars: 1 Votes
How can i put doors into glass curtain walls????????????????????
Tue, May 8, 2007 at 12:21:20 PM | Glass Curtain Wall doors
coreed
coreed Avatar
4 Stars: 16 Votes
here is a previous post by Tom Dorner on the Subject in question
The traditional way is to select the curtain panel and change it to a curtain panel door. This requires that you load into your project a door that is "curtain wall" based and then select the curtain panel you want to be a door and then change that panel into the curtain door you loaded. This method has some limitations and below is what I currently do. -------------------------------------------------------- One trick I have been using is to place regular door families into curtain walls. To do this, select the curtain panel and change it to a regular wall type. I usually make a dummy wall type the same thickness as my curtain panel thickness. Now that the curtain panel you have selected is a wall, you can simply insert a regular door family into it and it will schedule properly and can get placed onto a legend. The trick is to make sure that you use a door family with no trim and have the clear space between the mullions exactly the width and height of your door. When the door "cuts" your dummy wall, the dummy wall will completely disapear leaving just the door. ---------------------------------------------------------- HTH Tom
here is the link
http://www.revitcity.com/forums.php?action=viewthread&thread_id=1903
here is another link on the subject
http://www.revitcity.com/forums.php?action=viewthread&thread_id=2136
Edited on: Tue, May 8, 2007 at 12:24:04 PM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, May 8, 2007 at 12:26:45 PM | Glass Curtain Wall doors
You have to use curtain wall doors - not the regular doors.  To load these doors look in the door library. You also have to place these doors differently.  To place them, pull up an elevation of your wall.  Add mullions on grid lines if you don't already have them.   Get rid of the base mullion in the panel where you want the door then change the panel type to your door.
Wed, May 9, 2007 at 7:26:00 AM | Glass Curtain Wall doors
Safety
1 Stars: 1 Votes
I agree with the last post. You have to use curtain panel doors. It takes a small amount of time to learn how curtain walls exactly work, but is worth your while!
Wed, May 9, 2007 at 9:49:34 PM | Glass Curtain Wall doors
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
This is covered on my blog Revit Rants as well as many other FAQ's...
Regards,
Chris.
tagging curtain wall doors
Mon, Jul 30, 2007 at 3:14:12 PM
Panel tags for glass doors with frame in curtain walls
Thu, May 1, 2014 at 7:51:49 AM
How do I put doors in a Curtain glass wall
Wed, Feb 7, 2007 at 9:55:13 AM
Curtain wall: Change the glass colour?
Fri, Aug 27, 2010 at 10:13:58 AM
Curtain wall doors problem.
Sat, Sep 26, 2009 at 1:29:55 PM
Page generation time: 1.4721
