Forums >> Revit Structure >> Technical Support >> Plan Callouts have disappered. HELP!
4 Posts No Rating |
We have recently upgraded our Revit Structure 4 to RS2008. I noticed that the callouts (for my enlarged plans) on the foundation plan have disappeared. I went back and check my RS4 model and they had disappeared there. I can turn off my crop view and they reappear. I have also noticed that there is an option when I right click to reset the crop view. I reset it, then resize the view back down and they disappear again! What am i doing wrong? How can I get them back? I can't even add them and them show up.
16 Posts No Rating |
I'm having the exact same problem. Can anyone help us out? Surfrusty
I'm downloading this file but it sounds like this might fix it. http://usa.autodesk.com/adsk/servle...3112&id=9262388
2 Posts No Rating |
i am also downloading the update and will reply to this thread with the outcome.
2 Posts No Rating |
HAVE INSTALLED THE UPDATE AND IT IS RESOLVED. BIT OF A PAIN HAVING TO UN-INSTALL AND THEN RE-INSTALL REVIT AGAIN THOUGH...
2 Posts No Rating |
I was experiencing the same issue. After countless unproductive hours working under the assumption that I was doing something wrong, I discovered this discussion thread. The update resolved the issue. Adesk needs to build a software update utility into Revit so that we know when an update is available. I am under subscription and I didn't know it was there. I agree with shorn, it is a collasal pain in the arse, but at least it works correctly now.
19 Posts No Rating |
Hi, I'm having the same problem with the detail callouts disappearing in Revit structure 2008. Does this fix Revit Structure or just Architecture? Thanks
