36 Users Online (35 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Brick or Stone Overhang
Tue, May 8, 2007 at 9:47:27 AM | Brick or Stone Overhang
xelif
In section I have a standard brick wall assembly sitting on top of a foundation wall.  I need to show the brick overhanging the foundation by 1/2".  When i place these walls, the faces of the brick and the foundation line up -- how can i move the brick to overhang the foundation without the foundation moving also?
Tue, May 8, 2007 at 10:20:18 AM | Brick or Stone Overhang
jterrell
3 Stars: 5 Votes
Use stacked walls.
Tue, May 8, 2007 at 11:11:00 AM | Brick or Stone Overhang
xelif
Thanks -- of course, this seems to bring up other problems. The concrete supporting wall is 8" thick and has a 4" upstand to take the masonry. The level of the bearing ledge (supporting the floor joists) needs to be variable, as the floors are at different heights. it seems as though the stacked wall cannot accomodate split walls as part of their component... or am i missing something. Thanks again.
Hmmm -- playing with it seems to have given me the answer -- i've simply got 3 types of wall stacked vertically.  thanks.
Edited on: Tue, May 8, 2007 at 11:18:52 AM
Tue, May 8, 2007 at 11:40:17 AM | Brick or Stone Overhang
Dgodfrey
4 Stars: 4 Votes
If you haven't locked the alignment of the walls, select the wall you want moved and check the "Disjoin" button. This will allow you to move the wall independent of the other.
Wall Clading- Shaded stone/ Brick
Mon, Aug 24, 2009 at 7:05:04 PM
Rendering - Brick looks like a stone pattern
Fri, Jun 17, 2011 at 12:49:00 PM
Stone Wall
Tue, Aug 20, 2013 at 3:55:34 PM
Inserting stone into brick veneer
Mon, Nov 13, 2006 at 9:58:32 PM
acme brick patterns
Wed, Feb 8, 2006 at 11:35:38 AM
Page generation time: 3.0948
