114 Users Online (113 Members):
Forums >> Community >> Newbies >> aluminum slider attached to steel columns?
18 Posts No Rating |
I am trying to attach an aluminum slider (fleetwood) window to steel columns in my project. When I try to insert the windows, an error message comes up, telling me that there are no walls to attach the window to. I have attached a photograph of one of our projects to explain what I am trying to do. Very frustrated! any advice can help. thanks!
The window or door family you are using is a "wall hosted' element meaning it needs a wall present to insert itself into. You can make a non-hosted door or window family, but that is not something to undertake if you are new to Revit. You best bet may be to 'cheat' it by actually placing a wall between yur columns and then insert then insert the sliding door into the wall. If you work it correctly the wall can completely disappear leaving only the door.
thanks tom, i will try that. which links/tutorials would you suggest i look at and start practicing so i can eventually learn how to do this correctly? rita
Aluminum Members Beams and Columns |
Thu, Aug 6, 2015 at 7:05:21 AM
hidden steel columns showing as solid |
Tue, Nov 23, 2010 at 12:18:43 PM
Wide flange columns only show if tops are connected |
Tue, Sep 27, 2011 at 12:19:35 PM
Steel beam to steel/concrete column fixture (Noob question) |
Wed, Feb 27, 2013 at 3:18:10 PM
Steel columns do not display in detail view |
Mon, Dec 22, 2008 at 5:13:31 PM
Members: | 2030595 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
