173 Users Online (172 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Sheets in families?
Thu, May 3, 2007 at 2:35:50 PM | Sheets in families?
ThomasGerahrdt
In Revit Building 9:
 Is there a way to have sheets in a family file?
There is a sheets drop down in the browser... so can you define sheets?
-Thankers
Fri, May 4, 2007 at 4:16:17 PM | Sheets in families?
ThomasGerahrdt
*bump
Fri, May 4, 2007 at 6:10:48 PM | Sheets in families?
TomDorner
4.5 Stars: 25 Votes
No...sheets are only available in a project.
Why would you want to do something like this?
Tom
www.reviteer.com   http://twitter.com/Reviteer
Thu, Mar 27, 2008 at 3:07:42 AM | Sheets in families?
boydj
Iwould like to do it (unless there is a better way)
to print out shop drawings of idividual pieces I have created
Thu, Mar 27, 2008 at 12:43:54 PM | Sheets in families?
TJKENNEDY
3 Stars: 2 Votes
Is there any reason you couldn't load the family into a new project and print from there?
Thu, Mar 27, 2008 at 1:03:10 PM | Sheets in families?
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
What I have found to work is create a seperate titleblock family as a GENERIC ANNOTATION.
You can apply lables and what not to it then load it into you 3d component family. It will come in as a symbol so just pick the symbol command and place it.
Otherwise if this is too much of a hassel I'll just export it to CAD and finish it in there.
HTH
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Reordering Sheets
Thu, Nov 1, 2018 at 2:09:30 PM
Sheet Number Already in Use...I have ghost sheets.
Tue, Nov 21, 2017 at 8:47:11 PM
In place families above the view range are still appearing
Tue, Dec 23, 2014 at 9:17:06 AM
Linked Revit Model Sheets
Fri, Apr 5, 2013 at 12:04:29 PM
CONTROLLING THE ORDER IN WHICH SHEETS ARE PRINTED
Tue, Aug 5, 2008 at 1:18:32 PM
Page generation time: 0.5111
