80 Users Online (79 Members):
Forums >> Revit Building >> Technical Support >> change default settings of phases?
47 Posts No Rating |
i'm a relatively new user of revit 9.1 and 2008. i'm looking to draw/model/create on the existing phase rather than the new construction phase by default. i'm having to change each element from new to existing everytime after i make it. thanks.
The elements you addto the mdel take on the phase your view is set to. Simply duplcate your view and change the phase of the duplicated view to 'existing' Anything you add via this view will then be set to have been created inphase existing.
thanks, that was simple.
Group wide settings in Revit |
Mon, Aug 16, 2010 at 3:49:53 PM
default settings - can they be printed out? |
Fri, Dec 1, 2006 at 11:40:11 AM
3D View of Phases |
Thu, Feb 24, 2005 at 5:51:44 PM
default export to DWG settings |
Mon, Jul 2, 2012 at 2:38:13 PM
Capabilities to isolate phases |
Tue, Nov 28, 2006 at 5:43:02 AM
Members: | 2056445 | Objects: | 23069 | Forum Posts: | 152325 | Job Listings: | 3 |
