77 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Contour line intervals at different scales
Thu, May 3, 2007 at 10:51:35 AM | Contour line intervals at different scales
HCSCHULDT502
I am working on a project that has a large site (100+ acres).  I have developed the topography for the site and have multiple site plans scaling from a vicinity map down to specific building sites within the property.  I would like to be able to show contour lines at intervals of 5' or 10' on the larger scale drawings, and at 1' or 2' intervals on the smaller scale drawings.  I have looked under the "site settings" and it appears that the contour intervals setting applies to an entire project, and can not be controlled independantly in individual drawings.  Is this the case or can it be done?  Any help would be greatly appreciated.
Thu, May 3, 2007 at 11:03:52 AM | Contour line intervals at different scales
Under the Settings pulldown - site, you can set your primary & secondary contour intervals.   Under the visability graphics for the view you are in, you can turn on or off the primary or secondary contours.
Thu, May 3, 2007 at 11:12:58 AM | Contour line intervals at different scales
TomDorner
4.5 Stars: 25 Votes
In addition, you can define your own sub-categories under Settings>Object Styles>Topography   These new sub-categories can then be applied to your contours and controlled via view visibility VV as posted above.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Thu, May 3, 2007 at 11:14:15 AM | Contour line intervals at different scales
HCSCHULDT502
Works perfect, thanks a lot!
Thu, May 3, 2007 at 11:17:00 AM | Contour line intervals at different scales
HCSCHULDT502
One other question though.  It appears that Revit Architecture 2008 has not fixed the upside down contour lables; is this the case?  Or how to I flip them around to read correctly?
Showing contour lines at different intervals?
Wed, Apr 9, 2008 at 6:07:40 AM
Contour intervals
Thu, Apr 9, 2009 at 7:46:16 AM
Contour Lines Issue
Thu, Mar 27, 2008 at 11:35:30 AM
Possible to place contour lines to toposurface instead of points?
Fri, Jun 1, 2018 at 2:57:53 PM
Changing the amount of contours between intervals.
Tue, Sep 20, 2011 at 3:00:41 PM
Page generation time: 0.6195
