Forums >> Revit Building >> Technical Support >> Can a ramp be cut in plan view?
83 Posts No Rating |
Hi I'm not sure if I'm doing this correctly. I have a plan (Foundation) that has a ramp 350 insitu concrete. It goes from Foundation level up to Ground. From the attached view range image should the ramp be visible? It doesn't appear to cut. Any ideas for a solution? Thanks, Dave F.
Woops, uploaded wrong image
Rather use a sloped floor to make a ramp, then it should cut if your view depth is set correctly!
Tried that! but because it's curved! & as I'm sure you know, slabs can only fall in one direction! This causes the top edge of the ramp to fall! Which is not what is required. Can ramp not be cut or am I missing something?
A plan region will be the best solution around the ramp, use it to minimize the amount cutting, than you might use a solid white region hatch and some drafting lines...Check in your help files to explain plan region if you have not used it before. Sorry did not look at your attchment to see it curves!
Ramp won't show cut in plan view... |
Mon, Mar 3, 2008 at 4:19:04 PM
RAMP BEYOND THE CUT PLANE. |
Sun, Aug 17, 2014 at 12:41:24 AM
Shadows on plan view cast from cut plane |
Wed, Sep 24, 2008 at 9:24:32 AM
Problem Ramp with Wall (below) |
Thu, Sep 13, 2007 at 11:41:36 PM
ramp settings impossible |
Thu, Sep 1, 2016 at 7:08:06 AM
11
Members: | 2119085 | Objects: | 23205 | Forum Posts: | 152299 | Job Listings: | 3 |
