99 Users Online (98 Members):
Forums >> Revit Building >> Tips & Tricks >> Create Light Fixtures
![simonpeterong Avatar](user_avatar/26044.jpg)
![5 Stars: 3 Votes](/images/stars_5.gif) |
I've tried creating one, but I can't seem to understand hw it really works. I've tried creating a dual light (top and bottom) but the light comes from the sides. Hmmm... Any suggestions?
![rkitect Avatar](user_avatar/4651.jpg)
![4 Stars: 29 Votes](/images/stars_4.gif) |
Practice. Creating Light fixtures is an art form in itself. I can't even explain how some of my light fixtures fail where others work perfectly.
![robinballew Avatar](user_avatar/12071.jpg)
![3 Stars: 4 Votes](/images/stars_3.gif) |
Post the fixture. I will sometimes create 2 lights and bring them into a file as shared lights, seems to work more consistently.
----------------------------------- BallewDesigns.com |
4 Posts No Rating |
file > new family > light fixture. Create the light fixture in 3d geometry. Then apply a material to the surfaces that you would like light to come out of. The material will be the light, look in accurender for the material name with light in it. Then go to the family dialog box and at the bottom you put how many lumens, lamps (probably 2 for you) and watts. I have attached a family that i did, this one is not wall or ceiling based. Good Luck.
1 Posts No Rating |
Thanks for the post AR1237. The attached file helped a lot also. How you managed to make your solid only emit light from one side? Thanks again for the help.
turning on light fixtures |
Wed, Oct 16, 2013 at 10:53:10 PM
Light source inside the light fixture |
Fri, Feb 22, 2013 at 7:24:32 AM
Face Based Light Fixtures |
Tue, May 12, 2009 at 5:57:35 PM
Turning Off Light Fixtures In Linked Model For Rendering - How To? |
Mon, Jun 20, 2016 at 3:57:36 AM
revit 9: light fixtures |
Thu, Jul 26, 2007 at 3:46:39 PM
Members: | 2017166 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
