55 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Keyplan - Revit 2008
Wed, May 2, 2007 at 4:44:52 PM | Keyplan - Revit 2008
derxaj
3.5 Stars: 3 Votes
Has anyone attempted to create keyplans in Revit 2008 using dependent views?  I came up with the idea this afternoon, just seeing if anyone else has thought of it, or attempted it yet.
Wed, May 2, 2007 at 8:53:11 PM | Keyplan - Revit 2008
Tmifsud
Since key plans will need to be placed on multiple sheets I don't think dependent views aren't going to help.  Each dependent view can only be placed on one sheet.  I guess you could create multiple dependent views, one for each sheet, but that seems like overkill to me.   You could look at creating a Legend view for key plans as they can be placed on more than one sheet.  I found other comments related to key plans in thread below.  HTH Troy.
http://www.revitcity.com/forums.php?action=viewthread&thread_id=4699
Thu, May 3, 2007 at 12:08:22 PM | Keyplan - Revit 2008
derxaj
3.5 Stars: 3 Votes
Yah, I've read that thread before, and the downside to all of their ideas is that the key plans are not parametric.  Do you really think multiple dependant views are overkill if it actually enables you to have real parametric keyplans on your sheets?  I'm conservative when it comes to having mulitiple views or elements in projects, but honestly how many sheets on an average project would need key plans, 5 to 10 at the most?  Depending on how much memory that it would add to a project, I think it could work quite nicely.  What does everyone else think?  Anyone try it yet?
Mon, Dec 1, 2008 at 4:24:07 PM | Keyplan - Revit 2008
RevitNOOB
RevitNOOB Avatar
we created a keyplan using a generic annotation/ symbol.  ( revit 2009 ) we placed all the information inside the family types of the symbol and created yes/no parameters to turn off what you did and did not want to see.  although this works once it is in the sheets...it proved to be daunting to get all the parts correct.  I am trying to refine the process and get a generic model loaded for people to use.  hopefully in a few days from this post i can get something up for people to use.  hope this at least steers you in the right direction
Edited on: Mon, Dec 1, 2008 at 4:25:38 PM
how to import revit 2008 data to autocad 2008????
Tue, Apr 8, 2008 at 10:12:04 PM
REVIT 2008 - How to avoid Problems?
Sat, Mar 22, 2008 at 8:47:06 PM
Exporting a walkthrough path from Revit Architecture 2008 to Autodesk Viz 2008
Tue, Nov 20, 2007 at 12:37:44 PM
Revit 2008
Mon, Jul 30, 2007 at 9:17:23 AM
Suggestions on Revit 2008 Books?
Tue, Feb 5, 2008 at 1:30:37 PM
Page generation time: 3.2499
