30 Users Online (29 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> How to change the name of discpline and sub discipline in revit project browser?
Wed, May 2, 2007 at 1:55:30 PM | How to change the name of discpline and sub discipline in revit project browser?
leechriz
i am using revit MEP 2008 to setup Telecommunications and Audiovisual drawings. i am using default-Electrical template as base template. i would like to change the name of discipline and subdiscipline in project browser. I would to also add new discipline to project browser.
thank you
Thu, Jan 3, 2008 at 2:27:36 AM | How to change the name of discpline and sub discipline in revit project browser?
Chandira1
Hi,
You are using electrical template.You are not able to create discipline but sub discipline "yes" you can.
just hit the backspace and type in the name you want "audio visual".That is it you get a new subdiscipline.
ChandiraTechnical Support-AEC
Thu, Jan 3, 2008 at 2:34:23 AM | How to change the name of discpline and sub discipline in revit project browser?
Chandira1
hi,
just an addition ,you have to right click in any view.Click on view properties .Then hit the backspace button at subdiscipline.and type in the name which you  need.
Regards
Chandira
Technical support -AEC
Thu, Jan 3, 2008 at 10:20:51 AM | How to change the name of discpline and sub discipline in revit project browser?
NKramer
4 Stars: 9 Votes
I dont know how it works in MEP but in ARch there is no sub-discipline parameter. If you want you can add a project parameter to views of sub discipline or anything else you may want. You can then set your project browser to sort by those new parameters.
Just an FYI if you do this when you create a new view it will show up under the sub of ??? until yuo go in and change the parameter.
HTH
Nick
Tue, Jul 7, 2009 at 4:02:39 AM | How to change the name of discpline and sub discipline in revit project browser?
lanskaja
Hi!
It is great help!
It is very usefull to add a project parameter to views when I organaze collaboration.
Electrical in the browser
Wed, Jan 23, 2013 at 12:20:58 PM
RVT 2008 - Schedules to show in project browser under sheets
Tue, Sep 4, 2007 at 4:10:25 PM
Browser Organization and Drawing List
Mon, Jul 26, 2010 at 4:27:23 PM
Revit 9.1 / Architecture - Project Browser
Thu, Jun 7, 2007 at 4:18:42 PM
project browser
Fri, Dec 12, 2008 at 10:07:10 AM
Page generation time: 3.5005
