44 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Keynotes
Wed, May 2, 2007 at 12:46:19 AM | Keynotes
orange2
first time posting.. spent two years learning revit starting with revit 8..
operations i learned two years ago i either forgot or they don't work
anymore with revit 08.. seems like an ongoing cycle of uselessness
for me but i'm too mad to quit.. my first question is about keynotes..
the video shows to open a training project and go to a section view and hit
keynote>element>free-end and then just click an element in the
view- lol..  here's what actually happened.. first it says no keynote
family loaded.. ok fine i go to the imperial library and load the keynote tag..
then i click the element in the view like the video shows and instead
of getting a nice text label in a little box i get this message: "Unable to
load Keynote data. Check Keynote table location in Keynoting Settings."
i went to the keynote settings and browsed to the imperial txt pad and
found a sea of numbers next to a long list of text .. is there a way to
just label an element with a keynote without going through
a massive unsolved mystery?
Wed, May 2, 2007 at 7:02:52 AM | Keynotes
There is no real mystery, you just need to understand how key notes work.  Instead of following a video, I suggest you spend some time with the very well written REVIT help.  In addition, this subject is covered in the free to subscribers hard copy "Imperial Tutorials" and "User's Guide".  If you don't have those, you will not progress very far.
Wed, May 2, 2007 at 11:20:47 AM | Keynotes
Dgodfrey
4 Stars: 4 Votes
Yes, you don't need the .txt file if you aren't scheduling the keynote. I've never needed to schedule the notes as i don't use the CSI indexing, just the label. You have to define what the keynote will be in the properties of each material though and then you should be able to tag away.
Wed, May 2, 2007 at 5:03:36 PM | Keynotes
orange2
thanks guys and yes WWHub you are so right that's what i need to do
Keynotes
Thu, Mar 15, 2018 at 3:15:03 PM
Keynotes
Thu, Oct 6, 2005 at 5:13:33 PM
KEYNOTES: only one keynote txt file and legend?
Wed, Jan 17, 2018 at 12:33:01 PM
some keynotes not printing
Thu, Sep 15, 2016 at 4:43:39 PM
Keynotes - Ledgend management
Mon, May 11, 2009 at 7:01:29 AM
Page generation time: 1.7954
