40 Users Online (38 Members):
Forums >> Revit Building >> Technical Support >> elevation tag in section...
12 Posts No Rating |
i'm trying to add elevation tags in my section for existing levels that i had added. when i try to add the tag, it adds a new level. what am i doing wrong?! i'm sure there is an easy fix, i just need to know it! help!! thanks! revit 8 Edited on: Mon, Apr 30, 2007 at 1:14:45 PM
Edited on: Mon, Apr 30, 2007 at 1:15:02 PM
![Mr Spot Avatar](user_avatar/1073.jpg)
![4.5 Stars: 93 Votes](/images/stars_4.5.gif) |
If some of you levels are not showing in your section it is because the level (datum) extents are not intersecting where your section is cutting. Cut a section perpendicular and make sure its extents allow you to see the full width of your model and levels. Now grab the levels that aren't showing up in your other section and drag their 3D extents to align with your other levels or at least to intersect your section view.
Regards,
Chris.
location of the elevation tag and section tag |
Tue, Aug 10, 2010 at 10:07:10 AM
Elevation Tag |
Mon, May 29, 2006 at 7:29:36 AM
Adding a Tail to Interior Elevation Tag |
Fri, Mar 14, 2014 at 1:10:11 PM
updating/changing elevation tag types |
Wed, Mar 19, 2008 at 9:49:46 AM
Elevation Tag with same name |
Fri, Apr 3, 2009 at 1:29:48 PM
Members: | 2022388 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
