63 Users Online (62 Members):
Forums >> Revit Building >> Technical Support >> Sloping floors in two directions
1 Posts No Rating |
I'm trying to create a floor slab for a parking garage that slopes in two directions. What is the best way to do this since the slope floor arrow apparently only allows the slope to occur in one direction?
You are correct.
Currently the method i'd used to create a floor sloping in two directions would be to create an in-place floor family.
I'd then create a solid, extrusion to one of the sloping planes, then use a void to cut the remainder off to get the second sloping plane.
This will most likely mean making the slab thicker that what it would be then using voids to cut it back to size.
do you have any other solutions to a floor that slopes in more than one direction, or is your current solution still the best one?
17 Posts No Rating |
Why not use a roof to create your floor....you can still structure it the same but it allows for more features when considering slope.
Urgent Help ! Sloping Floors |
Wed, May 4, 2011 at 4:04:04 AM
Rendering in different directions |
Mon, Dec 15, 2008 at 10:49:29 AM
how to do an overpass/bridge |
Tue, May 19, 2009 at 10:54:08 AM
Revit 2010 Sloping Roof in in two directions at once |
Fri, Aug 20, 2010 at 8:34:00 PM
Ceilings sloped in two directions? |
Thu, Nov 11, 2010 at 12:07:26 PM
Members: | 2030517 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
