97 Users Online (95 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> API?
Fri, Apr 27, 2007 at 12:05:03 PM | API?
ArchWestCY
4.5 Stars: 7 Votes
What is the API that is referred to in the current poll?
ArchWestCY
Fri, Apr 27, 2007 at 12:11:20 PM | API?
TomDorner
4.5 Stars: 25 Votes
Application Programming Interface.
It is the external way into the Revit database and it allows you to add certain elements, change things, define new commands etc.
The Revit installation CD/DVD has a folder on it that has API samples, instructions etc.
Tom
Fri, Apr 27, 2007 at 12:19:09 PM | API?
ArchWestCY
4.5 Stars: 7 Votes
Cool. Should I be using this?  What kinds of things can I change with it?
ArchWestCY
Fri, Apr 27, 2007 at 2:17:19 PM | API?
TomDorner
4.5 Stars: 25 Votes
It is very powerful.  I'm not using it myself yet as it requires programming knowledge in the Microsoft .NET 2.0 environment and I'm not up to speed on that yet.
Examples of things you could do with the API:
- You could develop a command with it to number your doors based on what room they are in.
- You could load in room programs to a Revit schedule from Excel
- You could have a routine to setup sheets and views
Third party developers are starting to take a look at the Revit API and coming out with programs that make use of it.  In the structural world Robobat has released free extensions for Revit Structure 2008.
http://www.extensions4revit.com/n/e4r
Tom
Fri, Apr 27, 2007 at 4:43:35 PM | API?
ArchWestCY
4.5 Stars: 7 Votes
That's really cool.  We are looking for more ways to automate with Revit.  Thanks for the tips.  I'll have to look into it further.
ArchWestCY
Revit 2013 API
Mon, Dec 31, 2012 at 10:32:36 AM
Create Your Own BIM Tool in Minutes with bimU.io Viewer API
Thu, Sep 24, 2020 at 5:51:51 PM
Add size_lookup formula via Revit API
Mon, Mar 21, 2016 at 8:53:25 AM
API For all room elevations in one building model
Wed, Dec 17, 2014 at 1:19:51 AM
Programming macros with the revit API
Wed, Feb 1, 2012 at 4:33:56 AM
Page generation time: 1.3898
