79 Users Online (78 Members):
Forums >> Revit Building >> Technical Support >> 3D view with linked file
18 Posts No Rating |
My rendering wont come out with color on the files that i loaded into my project. They are all a yellow color. Also, i cant make my 3d views larger to fit on my sheets. Please help!
![4 Stars: 13 Votes](/images/stars_4.gif) |
If you could, I would post a small test file of your template with a wall or two, or whatever you are saying turns all yellow and we'll see if we can find the problem. The 3d views problem I assume you went to View>New>Camera and that created a perspective view for you. You drag this onto your sheet and it is teeny tiny. In order for you to have it fit onto your sheet, whatever size you need it to be, if you go to your 3d view and select the crop region, a size indicator will pop up on the options bar. Make the size that you need for your sheet first. If you don't have a crop region, click the check box for it under properties. Your view will still be small, but sized correctly. Now what you need to do is hit the Dynamically Modify View icon, the one with the eyeball and 3 arrows. Click the field of view tab and select In/Out and dolly the camera in to fit.
Edited on: Thu, Apr 26, 2007 at 5:43:17 PM
Linked Revit Topography file displayed in hidden lines in 3d view main bld file |
Sat, Jul 7, 2012 at 3:38:16 PM
Linked files in more than one view |
Thu, Sep 22, 2005 at 12:11:19 PM
Problem exporting view with linked CAD file |
Wed, Mar 18, 2009 at 3:46:34 PM
Linked File Visibility Management |
Thu, Jan 3, 2008 at 6:11:30 AM
Family from linked file not visible |
Wed, Nov 18, 2015 at 12:16:18 PM
Members: | 2017094 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
